Drilling through saddlebags?
Old Jan 21, 2024 | 10:40 AM
81shovelhd!'s Avatar
81shovelhd!
Default Drilling through saddlebags?
I'm preparing to put saddlebag rails on my 2010 RK.
For those that have done it, what did you use to mark the post locations?
Pencil doesn't work.
I tested a spot with a Sharpee and it came off with mineral spirits.
Any suggestions?
Tx!
Old Jan 21, 2024 | 11:02 AM
TheMurf's Avatar
TheMurf
Default Drilling
Use painters tape on the bags, measure twice, place a magic marker then mark a dot on the spot you want to drill the holes.
Put an X through the magic marker dot.Then use a center punch in the center of the X in the magic maker spot. Then carefully drill the holes you need.
Old Jan 21, 2024 | 11:06 AM
LoneRiderFLH's Avatar
LoneRiderFLH
OEM bags are marked with hole locations
Old Jan 21, 2024 | 02:16 PM
81shovelhd!
Tx man!
Needles to say you drille throught the TOP of the bag.
The factory hole markers are on the NSIDE......and not all of mine are clearly defined.
Old Jan 23, 2024 | 07:01 PM
OLD 96's Avatar
OLD 96
Not that this will help the situation. I went to put a rack on the tour pack. Because. For some reason HD did not put a rack on the 2018 Ultra Classic. I cut templates measured and marked meticulously over and over. To be positive to place holes exactly where they should be.. Before I drilled I opened the lid to the tour pack and saw molded into the plastic the exact marks of where to drill for the rack.
Old Jan 23, 2024 | 07:36 PM
81shovelhd!
So.....you drilled from the INSIDE.
I was planning on doing it through the top with bags on bike.
Last time I looked inside I could only see 3 molded marks on each.
I'll hafta look again.......tx!
Old Jan 23, 2024 | 08:27 PM
OLD 96's Avatar
OLD 96
Yeah. Well. It doesn't make any difference which side that you drill from. I looked at my marks on the top and checked the places molded into the lid. They lined up. So. I knew that HD had thought it out . This is where the holes should be for a luggage rack on top of the tour pack. Drilled from the inside of the lid. Saddlebags?. IDK. You on your own.
2011BlackGlide
Sep 10, 2021 01:49 PM
Wisenheimer16
2014-2024 Touring Models
55
Jan 7, 2020 02:19 PM
IronPhil
Jan 26, 2015 08:39 AM
jayride
General Topics/Tech Tips
Sep 10, 2009 08:24 PM
russl179
Jan 22, 2008 06:54 PM
