Timing, carb or something else?
Old Oct 31, 2024 | 04:20 PM
marcodarq's Avatar
marcodarq
thats not a big amount of fuel and shovels want to run rich. you did not mention what kind of pipes you have on it. make sure your enrichner is functioning correctly, confirm you accel pump adjustment. are you running a VOES switch? make sure you do not have any vacum leaks. and make sure your flot level is in spec. idle mix screw 1-1.5 turns out. then report back.
m
Old Oct 31, 2024 | 08:47 PM
tinymike66's Avatar
tinymike66
m
Pipes are Dual with straight fishtail and I installed drag 8" baffles wrapped to bring down the loudness.
I pulled enrichner, cleaned everything
No VOES
Accel pump I'll get to ok Monday
DRott
Aug 20, 2022 09:04 AM
DRott
Twin Cam Motors
Jul 22, 2022 08:40 PM
Shoveljennings
Shovelhead
Oct 20, 2017 08:24 AM
druminharley21
Apr 15, 2009 07:41 AM
Timboto
Shovelhead
11
Sep 21, 2007 06:07 PM
