1980 fxs start problems
Old Oct 19, 2017 | 05:04 PM
Shoveljennings's Avatar
Shoveljennings
Stage I
Default 1980 fxs start problems
I recently bought a shovelhead without an ignition or carb set up. I put a new points set up new plugs, wires, and a new mikuni 38mm vm on it. It has Andrews b2 and converted to solid lifters with a lsr 2 into 1 on it. It’s a kick only. After kicking and kicking and kicking I finally said f it and pull started it. It ran great once I got it going but would only run with the enrichner on while giving it throttle to keep the rpms up. Plugs after that we’re obviously baked black from choking it like that. Replaced plugs and have adjusted the air screw with only a couple kicks of hopes and one start and die kick over. Exhausted I don’t know what to do anymore. Pushrods are adjusted great ignition is static timed great and no intake leaks.
Old Oct 19, 2017 | 07:35 PM
johnjzjz's Avatar
johnjzjz
its not rich enough plus that's not the carb you want to be using great iron head carb
Old Oct 20, 2017 | 08:24 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Open the throttle squirt a little fuel in there and kick it over.. if it starts tare apart the carb and find what's plugged or get an S$S Super E... They work so much better....
fergerburger
Shovelhead
Sep 22, 2015 12:43 AM
leadsled70
Aug 7, 2014 08:26 AM
dr_ransom
Shovelhead
Mar 6, 2013 01:17 AM
gpaxtell
Ironhead
13
Jun 22, 2009 07:05 AM
Beeracuda
Exhaust System Topics
Feb 19, 2007 01:38 PM
