Inner fairing brass nuts
Old Dec 21, 2024 | 11:34 AM
fastsoup's Avatar
fastsoup
Default Inner fairing brass nuts
Howdy,
So I have tried it all...super glue, cement, epoxy, and even replaced with one of the brass repair kit style...everytime I button up the fairing, the one nut just keeps spinning...windshield loose on the right corner.
Anyone have a more permanent fix before I end up just replacing the inner fairing 🤦🏻
Old Dec 21, 2024 | 11:41 AM
theheder's Avatar
theheder
https://a.co/d/8wzJCP6
these are what I used.
I replaced them once and never had a problem ever again.
Old Dec 21, 2024 | 11:43 AM
fastsoup's Avatar
fastsoup
Tried that already...it's currently in place...just spins.
Old Dec 21, 2024 | 12:06 PM
Taxgod4u's Avatar
Taxgod4u
is there enough plastic around it to put in a set screw?
Old Dec 21, 2024 | 12:19 PM
dafrisco's Avatar
dafrisco
Try 2 part epoxy for plastic in hole then put the brass insert in. Or put the epoxy on the outer brass and screw it in.
Old Dec 21, 2024 | 12:25 PM
fastsoup's Avatar
fastsoup
Tried this with the original insert - never held
Old Dec 21, 2024 | 12:35 PM
fastsoup's Avatar
fastsoup
Yes...currently has the replacement insert inside
Old Dec 22, 2024 | 07:17 AM
memphisharley's Avatar
memphisharley
fill the hole with jb weld then put the insert in.
Old Dec 22, 2024 | 11:16 AM
fastsoup's Avatar
fastsoup
Yeah that was my next move. Try to find some strong commercial grade stuff and refill the hole, let it set, and then drill a small hole and set the brass insert...hopefully that works...otherwise it's a new inner fairing.
Old Dec 22, 2024 | 11:39 AM
hardheaded's Avatar
hardheaded
I put a couple in with JB Weld a few years ago and they are holding great.
