CANBUS
Old Feb 12, 2025 | 12:43 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Jackie Paper
See them all along with what they are. In a bluereader, you can then click hit for a further description of what also may really be the issue affecting that code.
I get it. You really don't need it as long as you have a Service Manual, or search Google or YouTube. Set bike and click thru them.
I just ask a question to the first poster.
Keep forgetting about the stalkers.
What you are missing is that the OP, is simply trying to find a place to connect his lights and control them. As he states the switches are gone for accessory control and it's probably done via CAN and using an app on the display. I suspect that HD has something already.
Old Feb 12, 2025 | 04:00 PM
rigidthumper's Avatar
rigidthumper
Correct- on the 25 models, you connect heated grips (or whatever acc to connector 325), then activate with Digital Tech.
Old Feb 13, 2025 | 07:20 PM
marcodarq's Avatar
marcodarq
Just so you guys know, that fancy new red dlc connector that came out in 21, i belive, is the motorcycle equivalent to the multi manufacturer standardized dlc connector.same one on all the asian platforms as well.
m
Old Feb 14, 2025 | 09:17 AM
Jackie Paper's Avatar
Jackie Paper
m
Thank you. All that needless fussing.
Least that ought to limit it to one adapter. Not 12.
Old Feb 14, 2025 | 11:24 AM
Max Headflow
Here is the pic, AFAICT.
The original connector is obsolete, big and not waterproof which is really the reason why it should not be used on a motorcycle.
Old Feb 14, 2025 | 12:11 PM
marcodarq's Avatar
marcodarq
the one adapter for my Snap On scan tool was, no bullshit, 1000 dollars!!!!!!
no bullshit!!!
1k
m
Old Feb 14, 2025 | 12:32 PM
Goose_NC's Avatar
Goose_NC
no bullshit!!!
1k
m
WOW!!!
May 23, 2023 08:08 PM
coop creek
Electrical/Lighting/Alarm
Nov 18, 2020 07:30 PM
MotoDude
2014-2024 Touring Models
Nov 7, 2020 10:28 AM
tiolevine
Audio Systems
Sep 11, 2014 12:00 PM
gdbro4
Feb 20, 2008 10:34 AM
