Bike dying
How are the seals on throttle body?
At idle there is less fuel and lack of sealing could reduce it more.
How is the inside of carb?
Has anybody cleaned the carb?
End the lesson.
Chances are, not positive if fuel related you would notice the RPMs dip or act funny if starving for fuel. Sounds like the bike just dies, and can't be restarted for awhile. So I am thinking electical. Sine he has lights, I am thinking not the main breaker.
He could carry a plug with him, simply unplug a boot, stick the spare plug in, to check for spark. He has replaced the coil. Could be a sensor or ignition module. Kinda doubt loose wire cause it starts up eventually.
I am assuming bike cranks over, but does not start, since he mentioned spark plug wrench.
Prior to fuel injection, the filter screen is on the petcock, located in the fuel tank.
They do get clogged with rust, tank coating, etc and can stop/slow down fuel flow.
It may be worthwhile for the OP to drain/suction the gas out of the gas tank, remove the tank, remove the petcock and inspect the filter screen.
OP, if you are going to do this, get a HD Service Manual for your bike, you can thank me later.
They can still be purchased at the dealer Ref: 24
62166-81A
FILTER FUEL VALVE
Price: $16.33
Lesson completed, there will be a test later - maybe.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
Also if the screen was dirty, it would not account for the bike starting in 20 minutes.
He also said he was getting gas
The 20 minute wait, makes me wonder if electronic device, that is cooling down and the starting..
