General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Empty the bottle the drained flush fluid goes into, then flush a little more into the bottle so the fluid is clear then measure it. Once you are at or below 1% you are good.
To properly bleed one with ABS you need the software to cycle the abs while bleeding. I use Daytona Twin Tec. You can do a manual regular bleed, but the equipment cycles the abs while bleeding to ensure complete flush and new fluid in the ABS unit.
