PIN Required - Other Reasons?
Old May 17, 2025 | 11:46 AM
marxman's Avatar
marxman
Default PIN Required - Other Reasons?
Hi All,
I have an issue where my bike more often than not asks me for my PIN when I power it up.
I know the PIN so I can start is however the bike itself has a new battery (last summer), sits on a tender over winter, and I have replaced both Fob batteries.
Once in a while the bike will power up normally, but as mentioned more often than not it asks me for the PIN now.
Does anyone have any ideas as to what else I can check to try to stop this? It's only started happening within the last year.
Perhaps take it to a dealer to have it reprogrammed / rekeyed?
thanks for any suggestions.
Old May 17, 2025 | 12:03 PM
rigidthumper's Avatar
rigidthumper
Check the voltage of the battery in the Fob- new is no guarantee of good. The system needs the Fob batteries @ ~3.2VDC to transmit properly, and their range (which deteriorates over time) is about 3' when new. I had a bunch of wally world CR2032 batteries @2.8 volts out of the package
If the voltage is ≥ 3.2Volts, it's possible the antenna module may be failing. Cheap enough to swap- part number is 68956-07, retail is less than $20
Old May 17, 2025 | 12:10 PM
marxman's Avatar
marxman
This is a great suggestion... I'll remove the seat and see if I've damaged the wiring, and perhaps order a new one.
Old May 17, 2025 | 04:04 PM
Buelligan666's Avatar
Buelligan666
Does it happen in one particular place more often than anywhere else? It could be radio interference.
COZWV
2014-2024 Touring Models
Oct 1, 2023 01:15 PM
Rickr01
Nov 3, 2016 01:08 PM
DJFriar
General Topics/Tech Tips
May 30, 2015 07:19 AM
Duderino619
Jul 6, 2013 06:40 PM
grock
Sep 18, 2008 12:56 AM
