Speedometer Calibrator
Old Aug 3, 2025 | 10:43 PM
randallissimo's Avatar
randallissimo
Default Speedometer Calibrator
My speedo on my 1996 Dyna died so I put on a used one from a 2000 Sportster I had. Put on a new Deutsch 12 pin connector, making sure all the wiring matched up. Breadboarded a contraption on my bench to add 20K miles to the odometer so it matches what I had. Looks good, works good. Added the tach as well.
Now all I need is an in-line calibrator to make the speed correction. The Dakota SIM-1 looks great, small and super easy to use at about $150.
There is also another one sold under various names such as V-Factor and others. It is half the price, and assume does the same job.
Issue is, the SIM-1 looks weather tight, but the other one does not, at least not in the stock photos.
Any thoughts on this?
https://vtwin.parts/harley-davidson-...dometers-48640
https://www.dakotadigital.com/index....od/prd1011.htm
Old Aug 4, 2025 | 05:09 AM
GLFLSTCI02's Avatar
GLFLSTCI02
I have installed the SIM 1 on two bikes of mine so far, an 02 Heritage and just this past Friday on my 1995 Dyna, both bikes had modified final drives. Super easy to set up with a GPS and I have not had any problems with reliability. The SIM 1 looks weather tight enough for under the seat of the Dyna. Since you don't need to use it after the initial setup you could always tywrap a small parts bag over the contraller for extra protection.
Gene
Old Aug 4, 2025 | 01:12 PM
randallissimo
I thought about the plastic bag protector for the calibrator, but then we are into the area of trapping moisture in. Never really bought into that idea.
Lugubre
Mar 31, 2024 02:06 PM
jlb2782
May 2, 2019 11:34 AM
RAWHIDE07
Feb 28, 2011 09:03 AM
Rocket Man
Aug 14, 2010 12:19 AM
mumeral
Mar 23, 2010 08:03 AM
