clear coat repair
Old Dec 13, 2005 | 10:47 PM
wsg's Avatar
wsg
Default clear coat repair
Ok Like bone head I used a buffer to wax my bike and of couse there is a small area that I removed the clear coat now I have been told it should be a fairly easy repair but this base clear is new to me I have no fear using a paint gun(touch up) might even get an airbrush which I have never used before, has anybody ever repaired there clearcoat any suggestions on the proper way to do this just asking before I go out and find some clear to do this with....would this be the same as I see in some arosol cans
Old Dec 14, 2005 | 06:56 PM
LAF's Avatar
LAF
Default RE: clear coat repair
Are you sure you are through the clear? What are you seeing?
Old Dec 14, 2005 | 08:25 PM
wsg's Avatar
wsg
very dull paint I would assume it is the clear that is gone as all shine is lost from what I have been told the paint is base clear the ride is an 88 flhtc , tried to get shine back with more wax but no joy it is in a horrible spot or I would just leave it
Old Dec 15, 2005 | 01:21 PM
HDF Tech's Avatar
HDF Tech
The 88 MAY be a laquer paint. If it is , you should be able to clean it free of wax and recoat it with laquer clearcoat. Allow it to dry for a week after a few applications and some fine polishing compound will bring up the shine after an easy sanding with 1500 wet sandpaper very easily for any overspray in the area.
You may also be able to get a spray can of the color touch up and just dust the area where you went through the clear and follow up with the proceedure above. You may find the touch up can HERE OR J&P cycles.
If it was a later model, they use urethane paint systems that require a different approach such as clearing the entire tank.
If you need access to purchase the stock paint, PM me and I'll give you some links for it.
Old Dec 19, 2005 | 09:49 PM
wsg's Avatar
wsg
Thanks for the info no luck on stock at the link I will PM and see about the other links...
Old Jan 6, 2007 | 12:59 AM
jerry2005dyna's Avatar
jerry2005dyna
ORIGINAL: wsg
dude, you did not go THROUGH the clear coat with a buffer ..... you may have damagrd the finish of the clear with teh buffer but to go through??? wow ... anyhting is possible but that is exceptioanlly ... ummm... difficult (stupid .. lol) sorry
Uncle Bull
Powdercoat & Paint
Feb 6, 2014 04:59 PM
kamut
Feb 20, 2013 05:37 PM
Ace07FXDL
Powdercoat & Paint
Jul 3, 2012 04:27 AM
dspencer
Aug 24, 2011 07:31 AM
PPBART
May 21, 2011 06:37 PM
