upper belt guard bolt stripped
Old Jan 1, 2006 | 04:44 AM
veniculum's Avatar
veniculum
Default upper belt guard bolt stripped
I bought a lower belt guard the other day and it was a really easy install. The dealer recommended that I buy the chrome hardware for the upper belt guard. I figured what's another couple bucks so I bought it. Turns out, the new chrome bolts are torx, but the existing bolts (front and back) holding the upper guard are hex. The one closest to the rear (with the nut) was real easy..came right out. Well..the front one was a real bi*ch...and needless to say, I stripped the bolt. I'm not sure what I did wrong...it wasn't like I was using a little allen key...I was using a socket and it was definitely the proper size. Any suggestions on how to remove a stripped hex bolt? Is drilling the only way out??? If so, do I need a special drill bit? Thanks very much!
Todd
Old Jan 1, 2006 | 10:18 PM
pococj's Avatar
pococj
Default RE: upper belt guard bolt stripped
Did you booger the head or the threads? If the head, try a vise-grip; if the threads, you might be stuck drilling it out. It's probably a Grade 5 (3 lines on the head), so you can use a regular drill bit, but use plenty of coolant to keep from burning it.
Old Jan 2, 2006 | 03:28 PM
PAYLRYDER's Avatar
PAYLRYDER
6th Gear
last time i stripped a hex head i used a vise grip like pocoj said and it took a little time but came out. just make sure that you put duct tape on the vise grip so that you do not scratch anything while your turning it seeing how you will have to put the vise grip right up to the bike.
Old Jan 27, 2006 | 05:41 AM
wlbowers's Avatar
wlbowers
Sears have some new toys. They look like a socket but have reverse cam channels that will grab the head of a stripped hex bolt and bite down on it.
Good Luck
Old Jan 27, 2006 | 02:26 PM
bobcowan's Avatar
bobcowan
Weld a nut on to the top of the rounded hex head.
wlbowers
Aug 11, 2017 04:55 PM
dustin1014
Aug 16, 2012 09:03 PM
dawg
May 5, 2012 08:40 PM
JoeEMT
Jul 2, 2010 05:30 AM
cdaxj
Mar 28, 2009 11:06 AM
