Bike will just shut off
Old Oct 4, 2008 | 07:08 PM
JW1200's Avatar
JW1200
Default Same thing with me today
My 91 1200 sporty died 6 times in 20 miles today. It seemed to happen as
I was in 3rd gear. You I would leave a sopt sign and bring the RPM;s up and shift then again, then as I would level off in 3rd or 4th. anout 40 mph. the bike would just quit. I pull over, turn the key off, put it in N and it would fire right up. Go down the road a bit and it would do it again. BTW I have a full tank of hi test, and tried the fule valve on...ON and RES.
Anyhelp??? Thanks.
Old Oct 6, 2008 | 11:29 PM
kbflash44's Avatar
kbflash44
Check the main hot wire (located under the seat the one coming from the breaker) to see if it's getting hot. Had this problem with a buddy's bike. He took it to two diff. dealers they couldn't find the problem. I found a spot about 3" long that was getting hot. I cut the bad place out and replace with a little bigger wire. He has not had any more problems with it since. Good luck and let us know how it comes out.
Old Oct 7, 2008 | 10:48 AM
JW1200's Avatar
JW1200
Seems like the "breaker" had poped out of it's holder, maybe it was shorting causeing the bike to quit. Thanks. Will "test" it soon.
Old Oct 10, 2008 | 11:23 AM
JW1200's Avatar
JW1200
nop...that wasn't it. I still need help.
Thanks
Old Oct 11, 2008 | 11:06 PM
d_slat's Avatar
d_slat
jw1200, Is it dying instantly or sputtering to a stop? if it sputters a little, like it's running out of gas, check to see that you have good fuel flow going into the carb, not that you have a fuel filter in the line that is restricted or a fuel tank that isn't vented properly
Old Oct 12, 2008 | 09:37 AM
JW1200's Avatar
JW1200
It dies instantly, and the tach goes nuts. I'm told it is the
timing sensor. I will put one on next week. I hope that is the
only problem. Got layed off and $ tight.
Thanks d slat
Old Nov 6, 2008 | 07:35 PM
ssmith236's Avatar
ssmith236
Stage I
Default 2003 nightrain
my bike started and ran for 2 min. and shutoff..won't turn over.. when I hit run button nothing, can't hear fuel punp,fuse is good to fuel pump,any ideas?
Old Nov 7, 2008 | 07:41 AM
JW1200's Avatar
JW1200
I replaced the ignition timing sensor plate, did it myself, took 2 hrs. everything seems to be fine now. Thanks for all the help guys.
Old Jun 19, 2012 | 01:41 PM
mugs's Avatar
mugs
Stage II
Default 2000 ultra suhts down while driving
I have a 2000 ultra classic. Only 10K mi on it. I was low on fuel, as the light just came on. I passed a moped, and upon getting back into my lane she shut down completely. No power to anything. I was going about 40mph. I turned into a car lot. Stopped the bike. Turned the ign to off, then back on, she light up and away I went. What could this be from? Not the first time it happened. Maybe bad gas from last year? Plus getting low on fuel? Bank angle sensor? I just filled it up with fresh gas, I will see if that was it. Will post soon.
Old Jun 19, 2012 | 01:42 PM
mugs's Avatar
mugs
Stage II
Default 2000 ultra shuts down while driving
