Help...BClem...like your information
Old Nov 11, 2004 | 08:45 PM
Augie's Avatar
Augie
3rd Gear
Default Help...BClem...like your information
I saw your response to the gear oil for transmissions. Bel-ray vs. Red line.
I am installing the 6-speed gear set and will run synthetic but what about the
break in period? Should I run regular petrolium fluid for the break in and swap it out for the Red-Line after 500 miles or what do you think?
Old Nov 12, 2004 | 02:38 AM
BClem's Avatar
BClem
Default RE: Help...BClem...like your information
No, you can use any lube in your gearbox that your heart desires. The break-in that is associated with an engine is not applicable to a gearbox since the 'seating' (such as rings) has no relevance.
Locate a source for Red Line Shockproof or MTL Gear Oil. You can extend the exchange period by double with either of these lubes, but then again; as your heart desires....
Just keep records of your oil application, sales receipts and dates. No-one can dispute proof.
BClem
Old Nov 12, 2004 | 04:17 PM
Augie's Avatar
Augie
3rd Gear
Default Breaking in my 6-speed
Thanx for the response. I do see about doing a lube change after 500 miles in the
instructions, so I guess use what I am going to use and think of it as a way of
cleaning out the gear set and by changing the gear oil after 500 miles it would remove any debrie or ? from the gears. I didnt think about the reason why we break in motors and why that wont apply in a gear box. So thank you again and I will let you know
how it went together.
Old Nov 12, 2004 | 06:28 PM
BClem's Avatar
BClem
Default RE: Breaking in my 6-speed
Yes, an initial change of oil at about 500 miles is a way of ridding the box of the assemblers hair, scabs and skin (if he wasn't careful and tidy). Seriously: there are lots of small pieces of metal associated with the machine work done in the bearbox and gearing and etc. that are missed in the clean-up of manufacture. Most are very small but still should not be allowed to become impaled into a gear tooth face or bearing roller or race.
I'm thinking hard about this six speed! I'm developing a severe case of: "I want one."
Thanks,
BClem
New Lenox Jim
15
Mar 23, 2018 09:23 AM
jokenroll
EVO
22
Jun 27, 2013 08:31 AM
Woodchuck
Jun 18, 2011 12:37 AM
Heath
Oil Archive (no new posts)
14
Apr 20, 2009 09:33 PM
wrencher
Apr 5, 2008 09:17 AM
