cleaning chrome pipes
Old Sep 27, 2009 | 10:06 AM
cayre's Avatar
cayre
Stage III
Default cleaning chrome pipes
any good suggestions for cleaning chrome pipes rain suit partially melted against one
Old Sep 27, 2009 | 10:07 AM
anubisss's Avatar
anubisss
Easy off oven cleaner sprayed on a rag away from the bike then wipe the pipes. Then clean easy off with your choice of metal cleaner or polish.
Old Sep 27, 2009 | 10:21 AM
cycletrash98's Avatar
cycletrash98
I use goop off from my local hardware store , it smells like lighter fluid.. but it works great!!
Old Sep 27, 2009 | 06:19 PM
RCB's Avatar
RCB
+1 Works well
Old Oct 19, 2009 | 09:36 PM
Photobiker's Avatar
Photobiker
I use an SOS pad, they are fine steel wool with a soapy stuff in it. It also acts kinda like a wax, works great on chrome wheels as well.
Old Oct 22, 2009 | 10:34 AM
FUZZY's Avatar
FUZZY
SOS or fine steel wool is best I've found. Works on all chrome.
Old Oct 22, 2009 | 12:46 PM
genedjr's Avatar
genedjr
Steel wool will scratch chrome and get worse over time. I suggest you try easy-off frist as it would not damage the chrome. But be careful not to get easy-off on anything else.
There are other chrome cleaners and polishes, but I would stay away from steel wool.
...gene
Old Oct 22, 2009 | 08:14 PM
StreetGlideRider's Avatar
StreetGlideRider
Stage III
Default Best Method to clean chrome pipes
Use 0 steel wool makes everything easy and wont scratch pipes I tried everything before and this is by far the best method
Old Oct 23, 2009 | 08:32 AM
RCB's Avatar
RCB
0000 steel wool works very well. Never had a problem with scratching. Just keep the pad wet/moist at all times.
Old Oct 23, 2009 | 11:05 PM
wahoo's Avatar
wahoo
Eagle One Wadding compound and elbow grease worked for me when I did the same thing at Deals Gap in May.
Easy Off works well also....
