Throttle Lock assembly ?
Old Oct 14, 2009 | 05:04 PM
Hockey Stick's Avatar
Hockey Stick
Default Throttle Lock assembly ?
So last night I was messing with my throttle. Took apart the houseing and removed the grip.
'07 FLSTC
As with any project I get into, I hear small pieces hitting the garage floor. Turns out to be the little curved pressure plate of the throttle lock screw, which presses up against the grip to hold it.
I found the pressure plate on the ground. The screw, spring, and c-clip stayed in place.
However, I also found on the ground a tiny rubber o-ring. ?? Not sure if this was part of the assembly, or just some little o-ring that was sitting on the ground from some other failed project. But it seemed to be of a size that would fit with this assembly.
I went ahead and put the assembly back together, placeing the rubber o-ring between the thumb screw and the pressure plate.
My question, does anyone know if a rubber o-ring is part of this assembly?
I actually did find this simple schematic on www.bikebandit.com, which does NOT show this o-ring. But don't know if correct. And this is for a 2005 FLSTC. Shouldn't be any difference, I'd guess??
Thanks for any help
Old Oct 14, 2009 | 09:28 PM
Kaycee's Avatar
Kaycee
I didn't have any o-ring in my throttle assymbly,Man you are lucky when I have parts fall out they usually roll across the street and get under the neighbors house.
Old Oct 15, 2009 | 11:40 AM
Hockey Stick
It's like they have legs, and a strong spirit for freedom, eh?
Thanks for the info. I'm plan'n to take that o-ring back out this weekend.
Old Oct 15, 2009 | 12:01 PM
dawg's Avatar
dawg
No o-ring that I know of. The o-ring sounds like the tiny one that I use on the Garmin zumo mount's security screw. Very tiny.
Old Oct 16, 2009 | 11:59 AM
Hockey Stick
Just for the curious...
I took that o-ring out last night and it suddenly hit me where it came from.
It came out of an HD tire valve stem cap.
This is the second time that little POS thing caused me headach. I took that thing and burned it properly in an old family ritual.
K.P RoadKing
Jun 24, 2017 05:25 PM
sajor
May 21, 2015 10:46 AM
ronyd
Apr 15, 2009 09:31 PM
bobros
Aug 30, 2006 09:13 AM
kd0dg
General Topics/Tech Tips
Feb 16, 2005 01:10 PM
