handlebars
Old Nov 10, 2009 | 05:19 PM
harlex250's Avatar
harlex250
Stage II
Default handlebars
I need to adjust the handlbars on a roadking custom 2007. Go through the headlight. do i remove the collar holding the bulb . or ?
Old Nov 10, 2009 | 05:23 PM
harlex250's Avatar
harlex250
Stage II
Default adjust handlebars
I need to adjust the handlebars on a 2007 roadking custom. I go through the headlight. Do i remove the ring holding the bulb to get to the bolt. If not then what.
Old Nov 10, 2009 | 05:36 PM
stevelonewolf's Avatar
stevelonewolf
You'll have to go through the head lamp bucket unless you have a police edition that has two small caps on your riser cover. Remove your ring,nacell,unplug your light,unscrew the top trim piece that hides your common line gap between the two halves,unscrew bolt to the front riser cover, pop off the ignition switch (on-off)cap take out the screws and the two piece clamp is exposed.
mikelikesbikes
Sep 15, 2012 12:16 PM
dlongo8241
Sep 9, 2011 02:58 AM
azzdog
May 6, 2011 06:31 AM
dart451
Nov 3, 2008 02:29 PM
sbkjo
May 11, 2007 03:44 PM
