1996 softail
Old Dec 2, 2009 | 07:31 AM
capas100's Avatar
capas100
1st Gear
Default 1996 softail
guys and girls, if you can help me i would by so grateful, ok what happens is when i give it throttle but slowly increasing through the revs my bike breaks down so much that i cant ride it. i have changed, the coil and leads the regulator rectifier the black box under the seat all the relays, the voes switch the battery, the battery leads, the capacitor, the carb just about everything, im going mad. suggestions would be appreciated. i nearly forgot the ignition sensor also.
Old Dec 2, 2009 | 08:32 AM
sqdealgeorge's Avatar
sqdealgeorge
Sounds like a short You've probably checked the intake manifold for air leaks and replaced the plug wires and the spark plugs and the gas flow from the tank etc etc Good luck keep us posted Just for kicks wire the coil + directly from the bat see what that produces
engr146
EVO
45
Apr 7, 2017 03:03 PM
jim bob39
EVO
Oct 14, 2013 08:40 AM
petewood70
EVO
19
Jul 1, 2010 06:55 PM
flyby
Jun 20, 2010 09:51 PM
Stkman
Jan 25, 2007 06:24 AM
