Rattling Gas Cap
Old Dec 30, 2009 | 12:47 AM
rich285's Avatar
rich285
Stage I
Default Rattling Gas Cap
I have a rattling gas cap which makes annoying noise. . After checking the seal inside, it looks fine. What else can I do?
Old Jan 31, 2010 | 11:21 PM
jungleman's Avatar
jungleman
My cap did the same thing on my 06 Heritage. A buddy of mine gave me a big o-ring to put under the cap. It worked but I really did not like it. I turned the cap upside down and put glue into the ratchet mechanism. It has worked well for a year now. Just do not tighten it up so much that you brake the glue loose.
Old Mar 22, 2010 | 11:20 AM
witter's Avatar
witter
hi rich i had the same thing on my 06 heritage. i took the cap off and turned it over on my workbench. took a blunt screwdricer and tapped the steel ring on the underside just enough to stop the rattle. there is an indent on bottom of cap and that is where i tapped it with the screwdriver and a hammer. just keep tapping around the circle and you will see that the steel gets pushed against the plastic and stops the rattle . hope this helps
killbasser
2014-2024 Touring Models
Jun 9, 2019 08:17 PM
Krazy8s
Jul 10, 2012 06:38 AM
Corndog
Oct 7, 2011 07:17 AM
1unclejojo
Shovelhead
Aug 12, 2008 06:22 PM
jlsporty
Apr 23, 2008 07:14 PM
