intermitant electric
Old Jan 30, 2010 | 08:12 PM
ghag's Avatar
ghag
Stage I
Default intermitant electric
i have a 02 softail efi it wasnt chargeing found out i had abad voltage regulator . installed it its chargeing good now , but i lose my speedometer and odmetor unpon acceleration then the engine light comes on .as i let off the throttle everything goes back to proper order . the problem doesnt seem to effect engine proformence or running i checked connections tightened all grounds it doesnt change things thanks g
Old Feb 10, 2010 | 11:59 AM
tech396's Avatar
tech396
6th Gear
Sounds like you have a failing speed sensor located in the trans housing...or moisture inside the plug at the sensor...
Bubba02
Classic
Oct 30, 2017 03:33 PM
jwarren
May 15, 2017 07:38 PM
nkauf21
Sep 28, 2010 03:52 AM
donr101395
Aug 23, 2009 01:34 PM
nz3204
Nov 15, 2007 02:39 PM
