Squeaky saddlebags
Old Feb 8, 2010 | 07:53 AM
newby's Avatar
newby
Default Squeaky saddlebags
Got a rattle/squeak thas been driving me nuts! Think I've narrowed it down to the saddlebags. Anyone have any ideas?
Old Feb 11, 2010 | 08:50 AM
big cahuna's Avatar
big cahuna
Might be the rubber hanger bushing where the hanger attaches. You'll hear the squeak when idling, but if you rest your leg on the muffler for a second it stops squeaking. Or check that one of the twist screw hasn't come out.,,
Old Feb 11, 2010 | 09:29 AM
Pacemaker's Avatar
Pacemaker
+1 on the rubber bushing that's on the mounting bracket which holds the muffler up to the saddlebag support rail.
Old Feb 11, 2010 | 09:47 AM
PistonPuller's Avatar
PistonPuller
Check mounting bolts on the fender. One of mine rattled loose and started squeaking. Also like others said check exhaust mounts, and check that your hardware on the latches are tight
Old Sep 1, 2015 | 09:40 AM
Keithhu's Avatar
Keithhu
Yeah yeah, ressurecting an old thread, rather than starting a new one.
I took my bags off the other day when I took my bike in for a rear rotor replacement.
Guess what - no squeak!
So - yes, a lot of people seem to have this problem, are there any good remedies?
Old Jun 23, 2017 | 09:32 AM
kenny55's Avatar
kenny55
Bringing this thread back up.
I have a 2017 Dyna Low Rider and just installed Saddlebags - rode with the saddlebags for a couple days then I installed a nightstick slip on. I get a very annoying squeak or chirping sound at idle that goes away when I accelerate. I did not recall squeaking prior to the nightstick. However when idling on the kickstand the squeak goes away if I hold both saddlebags to keep them from shaking. Everything is good and tight, nightstick has the little rubber bushing in place... etc.
Also, the saddlebags are supported by two bolts into the fender. There is no support on the bottom. They are the rigid leather H-D saddlebags. I'm considering making up some bracket to keep the lower part of the saddlebags in place.
Any comments/feedback welcome.
aroacha5446
Nov 9, 2017 10:16 AM
CycleManiac34
Oct 8, 2010 11:50 AM
TorturedZen
Jun 11, 2010 01:12 AM
Mermoto
May 5, 2010 10:12 PM
jayride
General Topics/Tech Tips
Sep 10, 2009 08:24 PM
