Rear Caliper
Old Jun 2, 2005 | 08:46 PM
MonteMuscle1970's Avatar
MonteMuscle1970
Stage IV
Default Rear Caliper
My bike has been sitting a while, and the brakes are stuck. I removed the front caliper, but how do I get the back one off? I removed the two hex head bolts from it, but it still won't budge. Is there a hidden bolt somewhere? The bike is an 86 softail FXSTC.
Old Jun 2, 2005 | 09:54 PM
pococj's Avatar
pococj
Default RE: Rear Caliper
I have an '87 Sloptail. It has the same brake as yours. There are only the 2 bolts holding the caliper to the bracket. Your pucks might be causing the problem. You might drop the wheel and remove the bracket and caliper, then work on getting the caliper loose.
Old Jun 2, 2005 | 10:08 PM
HDF Tech's Avatar
HDF Tech
You could try opening the bleeder and gently prying the pads back with something flat like a puddy knife
RodeoHard
May 25, 2025 12:41 PM
RodeoHard
EVO
May 31, 2013 08:16 PM
theosmithers
May 22, 2012 08:42 AM
trainwreak
May 6, 2011 08:42 PM
Hot_Pasta
Sep 12, 2010 10:30 PM
