Charging trouble FLHPI 04--Help
Old Aug 22, 2010 | 09:46 AM
Howard's Avatar
Howard
Default Charging trouble FLHPI 04--Help
I have 04 FLHPI renewed battery checked voltage at battery idle 13.5 and 3600 rpm 14.2 all good. I checked the charging system disconected voltage regulator from stator, regulator had 12.2 volts on each prong this is not a 3 phase system. the stator checked ok for continuity, could not get a resistance check, checked to ground each prong ok, checked acv at idle 24, at 2000 rpm 47 acv, 3000 rpm 70 acv, 3600 rpm 80 acv. I checked using 2 good vom.regulator is bad, but what about the stator? And why did I get the 13.5 and 14.2 volts at the battery with a bad regulator.
Louie Champan
Aug 26, 2016 08:11 PM
Jimhd2002
Sep 2, 2013 04:39 PM
motox_girl13
Jul 7, 2012 03:27 PM
mpaquette
Aug 20, 2011 08:59 PM
