Vibration
Old Aug 28, 2010 | 06:42 PM
Donnacc20's Avatar
Donnacc20
2nd Gear
Default Vibration
I have a vibration on my bike still after changing the motor mounts and doing an alignment, could it possibly be from the back tire? The bike only vibrates when in gear, I would hope maybe somebody else has had this problem and could give me any advise.
Old Aug 31, 2010 | 01:52 PM
dmercy's Avatar
dmercy
If the vibration is only in gear, you've eliminated the tire/wheel(s) and any frame issue I can imagine. Some vibration is normal. Care to share more detail?
Old Sep 28, 2010 | 07:46 PM
Donnacc20's Avatar
Donnacc20
2nd Gear
Default Vibration
The tires have been changed, clutch bearing has been changed, vibration is so bad still you can not see out of mirrors. Could it possibly be the transmission?
Old Sep 28, 2010 | 09:06 PM
peppi's Avatar
peppi
You may want to post what your riding, there have been recalls on some tires and other parts too so this info would get a better reply.
Old Sep 29, 2010 | 07:10 PM
Donnacc20's Avatar
Donnacc20
2nd Gear
Default Vibration
my bike is a 2004 FLHTPI , maybe this will help to find out more info
Old Sep 30, 2010 | 11:23 AM
rh8234's Avatar
rh8234
Not trying to be a smart a$$ - but you say it only vibrates when it is in gear. Does that include when it is standing still and in gear? If it is vibrating while standing still and in gear, then you can rule out the tires! If it only vibrates when moving AND in gear, at what speeds/rpms does it vibrate? Again, if it was a bad tire, I would not think putting it in neutral would reduce the vibration much while moving. All my bikes vibrate a tad if I lug the engine (RPM's below 2000). Need info so some of the folks on her can help!
T Man
Nov 8, 2025 09:34 AM
DIESEL-FUMES
Jun 24, 2019 05:19 AM
Paul32730
Oct 27, 2018 12:22 PM
grind4012
Apr 23, 2013 08:14 PM
Mr HOG
Jul 28, 2011 04:10 PM
