Headlights quit
Old Oct 20, 2010 | 12:30 PM
FATHD99's Avatar
FATHD99
4th Gear
Default Headlights quit
I was on my 99 Fatboy, coming back from a 4 hour ride, getting in a bit after dark.
Turning onto my street, my headlamp and passing lights went out.
Turn signals still work, then after about 50 yards, headlights came back on.
Ground wires and connectors under the seat look good and snug.
Any ideas?
Thanks!
Old Oct 20, 2010 | 03:54 PM
peppi's Avatar
peppi
Being you lost the headlight and passing lamps, it could be ground leg in the wiring or even a start of a bad ignition switch.You may also check the plug on the back of the headlight, a bad connection will cause heat and the plug can melt causing a bad connection.
Old Oct 26, 2010 | 10:28 PM
FLHTom1948's Avatar
FLHTom1948
Yeah, i agree; look for bad grounds; there is a wire at the fork bearings.
trashtrucker
Jul 24, 2017 05:45 PM
mikersix
Aug 7, 2014 09:25 AM
AtticusFinch
Sep 11, 2013 07:15 PM
00FattyT
Nov 3, 2012 03:38 PM
bmf73
May 1, 2011 11:43 PM
