fuel tank issue
Old Nov 22, 2010 | 05:29 PM
tattoofever's Avatar
tattoofever
Default fuel tank issue
hopefully this is posted in the right palce
im painting my bike(2003 softail efi ) and when i removed the fuel pump from the tank
i can see that the coating inside is starting to flake off its not too bad butt is flaking and will need to be adressed
my freind says i could just scrape up the loose peices and forget about it, im not tooo sure i agree ,seems like it will only get worse so figured id ask
1 has anybody used any of the sealers sold at dk or jp cycles?if so is there a better one to use or not use
2 im assumming the directions that come with the kit will be for a new tank
so is there anything diffrent with a used tank <im assumming ill be able to just scrape off the loose peices and apply the sealer?
3 does anybody have any tips or do and donts ?
thanks in advance for any help
Old Nov 22, 2010 | 06:43 PM
trozenhorse's Avatar
trozenhorse
you need to have a perfectly smooth surface to paint on, you wont get the desired results unless you prep the surface really well, others will chime in with the materials needed for the project.
Old Nov 24, 2010 | 12:11 PM
95custmz's Avatar
95custmz
Try the Kreem gas tank sealer kit.I've used it with great results. See http://reviews.ebay.com/How-to-use-t...00000000103420...
Old Nov 24, 2010 | 05:10 PM
tattoofever
ya i think dennis kirk sells that also ,any tips or do's and dont's ?
Old Nov 25, 2010 | 02:03 AM
95custmz's Avatar
95custmz
Dennis Kirk or JPCycles probably has the kit.I put acetone in the tank and swirled it around with bb's to get all of the rust and loose liner out.Then,I followed the directions on the kit.Plan for it to take up most of your afternoon because once you put the sealer in the tank,you have to rotate the tank about every hour or so to get an even coat.
Old Nov 25, 2010 | 07:50 AM
tattoofever
thabnks for the advice ,
Alain
Apr 30, 2015 06:33 PM
sprint12
Feb 19, 2014 09:40 AM
Can't Wait 2 Ride
Exhaust System Topics
Jun 22, 2012 10:00 AM
Bill918
Nov 12, 2007 12:48 PM
67xlch
Ironhead
Oct 27, 2006 03:41 AM
