87 flhtc
Old Nov 23, 2010 | 03:32 AM
bulldawg10's Avatar
bulldawg10
Default 87 flhtc
i have 2 questions ?
1- does anybody knows where the starter relay located
2- i have a new battery install when i go to start the bike all i here is a click to me i think i have to replace the starter other tell me the solenoid or the switch. i need some help this is my main transportation plus don't have money to take it to the shop
thank you for your time
Old Nov 24, 2010 | 07:23 AM
UltraNutZ's Avatar
UltraNutZ
1. right side cover bolted to the oil tank
2. i would start with the starter relay. take it off, bring it to an auto parts store close by and match it up. while you're there get a tube of dielectric grease.
then when you go to put it back on, make sure all the contacts in that connector are clean and oil free and put a coat of dielectric grease on them. check all wiring to and from the starter and solenoid. This will be a cheap fix, you just have to spend a little time making sure all connections are tight and rust free. Rust is an electrical systems 2nd to worst enemy behind water.
Hope this gets you going...
HarleyRick
EVO
Feb 21, 2017 08:52 PM
dyydjbb
Electrical/Lighting/Alarm
Oct 1, 2016 03:11 PM
wdb01l
EVO
May 31, 2013 09:59 PM
cookieonscooter
Jul 25, 2012 05:50 AM
Sling72
General Topics/Tech Tips
Aug 29, 2010 02:46 PM
