Primary drain plug
Old Jan 17, 2011 | 11:57 AM
grantb's Avatar
grantb
Default Primary drain plug
Hello-I have a 72 iron head sportster and the drain plug for the primary is stripped(case threads). Does anyone have suggestions on the best fix(oversize plug, heli-coil, and etc.) THank you for any help!
Grant
Old Jan 17, 2011 | 12:01 PM
Mike T's Avatar
Mike T
Drill and tap it one size bigger.
Old Jan 17, 2011 | 07:14 PM
10350's Avatar
10350
It depends on what level of skill you have, or how much you want to spend. Retap, or drill and tap is best. The cheapest fix is a rubber plug that expands when you turn it from an auto parts store. Personally, I would avoid helicoil. I used that solution in the past and it didn't work well.
Old Jan 22, 2011 | 10:08 PM
Gutman's Avatar
Gutman
That is ridiculous! A helic-coil will leak between the threads. Look for a shop that can install a Thread-sert and use a newer style plug. Remember, when the plug fails, it is in the line of tread patch.
sealdoggy04
Dec 11, 2012 08:08 AM
Frankster69
Sep 21, 2008 10:20 AM
rpmp3
Jan 20, 2008 10:12 PM
blainem
19
May 30, 2007 04:29 PM
bancquo
25
Jan 24, 2006 02:11 PM
