chirps
Old Oct 31, 2006 | 05:12 PM
Rem's Avatar
Rem
Default chirps
don't know if this is the best catagory, but here goes:
put gear drive cams in my 02 injected electra glide. everything went smooth and it runs fine. here's the 'problem': at about 22-2300rpm, mostly on decel, it 'chirps'. don't know any better way to describe it. the sound doesn't affect anything but does get annoying sometimes. at first i figured it was gear noise and blew it off. wonder if it could be an exhaust sound? (it is hard to tell exactly where it is coming from, and it doesn't do it at idle, or even while standing still) seems like way back in my memory i remember car exhausts doing this sometimes.
question: anyone have an experience like this after cam job? any ideas as to what might cause it? any thoughts appreciated.
rem
Old Oct 31, 2006 | 05:27 PM
sleepneagle's Avatar
sleepneagle
Default RE: chirps
may be your belt. clean it good with soap and water. use a wheel detailing brush on the rib side.
Old Oct 31, 2006 | 08:26 PM
pittguy's Avatar
pittguy
Default RE: chirps
Also check belt alignment and try removing belt guard if noise continues.
doo925
Jun 3, 2018 07:30 PM
JONNIEROCK
Jul 29, 2016 04:27 PM
juanbogrdo
Apr 19, 2011 11:24 PM
forever young
Nov 28, 2008 09:24 PM
LuckyRoadKing
17
Aug 15, 2006 06:26 PM
