07 fxstsse w thundermax autotune *HELP*
Old Sep 8, 2011 | 12:26 PM
hdmarkg's Avatar
hdmarkg
3rd Gear
Default 07 fxstsse w thundermax autotune *HELP*
Hi all, im glad someone told me where to post this.
i have a zippers thundermax w autotune on a 07 fxstsse. when the bike is hot and i shut her down if i go to start her, she blows the ecm fuse. the hd ecm works fine. the aic motor was changed.
any info on this? thanks hdmarkg
@ mlgottlieb@verzion.net
Old Sep 13, 2011 | 12:33 AM
1/9AirCav's Avatar
1/9AirCav
6th Gear
Not to state the obvious but If the unit only blows ecm fuses with the Thundermax ecm & not the factory ecm than it's the Thundermax ecm causing the problem. I love Zippers 80" hammer sportster kit but as far as the Thundermax autotune ecm's I am not impressed. Nothing but issues from what I have seen. Does your security light stay on? That's also a Thundermax common issue.
An additional note: Most 2007 Softail's had recall 0130. Basicaly the positive batt cable chafes on a oil tank weld. The recall includes inspecting the cables & installing a plastic tray for the cables. Give your vin# to the local dealer & see if it's been done.
hdmarkg
Sep 9, 2011 07:22 AM
rbabos
Dec 15, 2009 07:54 AM
jack0007
Exhaust System Topics
Apr 28, 2008 09:56 PM
Jezcruzen
Sep 18, 2006 08:03 PM
barrygreen
May 12, 2006 11:33 AM
