Sporster Crank Covers
Old Nov 25, 2006 | 02:41 AM
Pritch's Avatar
Pritch
Stage III
Default Sporster Crank Covers
I would like to remove the crank covers to polish them. I've been told not to try to take the primary cover off because of shims on the inside but I don't know about the right hand side. My bike is a 1993 1200 sporster and there are 11 cap screws showing. If I remove them will the cover come off? Is there anything I need to be aware of when removing
Old Nov 27, 2006 | 09:26 AM
DJJSR's Avatar
DJJSR
Default RE: Sporster Crank Covers
I've had my primary cover off numerous times. There are no shims. If you're going to take the covers off to polish them be sure to follow the torque specs and sequence in the service manual when you assemble it. Otherwise you may end up with leaks or stripped threads.
Old Nov 28, 2006 | 02:43 AM
Pritch's Avatar
Pritch
Stage III
Thanks for your help. I think I'll go back to the primary side and have a think about the cam side. Do you know, if I take the cam cover off will I need to reset the cams or timing?
Old Nov 28, 2006 | 07:42 AM
xxxflhrci's Avatar
xxxflhrci
The shims are under the cam cover.
brettnbama
Softail Parts
May 7, 2011 10:39 AM
dhamilton20
Mar 11, 2010 11:11 PM
Nixon1200
Mar 12, 2009 07:16 PM
dansflhti
Dec 7, 2008 11:54 AM
Moon Wolf
Ironhead
Sep 7, 2007 11:04 AM
