Motorcycle jack (Sears)
Old Jan 31, 2007 | 10:24 AM
ultraultra's Avatar
ultraultra
Default RE: Motorcycle jack (Sears)
I bought one from Northern Tool. Biggest piece of sheit I ever owned. First off, I couldn't roll it under the bike, it wouldn't go low enough. I had to either hold the bike up with my hands and roll the jack with my foot, or get help. After using it about 4 times, it started leaking. Now I only use it as a transmission jack when working on a cage. I don't have enough room in the garage for a lift. I'm just screwed![:@]
Old Feb 15, 2007 | 01:20 PM
cadillac's Avatar
cadillac
Ive used the Sears red jack on my 2000 Dyna for over 2 years now, no problems. But because I have a Dyna, I had to get the "lift kit" from HD. Problem being the tranny sits lower than the frame on Dyna's so these 4 neoprene blocks take care of that problem. My bike was also lowered 2" from stock and it takes a little bit if wiggling to get the lift & blocks under the bike in the right spot. I liked the idea about putting the bike on 2 2x10's so the lift fits under it easier.
Bob
Old Feb 15, 2007 | 01:36 PM
UmpOne's Avatar
UmpOne
I have the yellow Craftsman jack, used for my 2007 Street Bob. If I had to do over, I would buy the J.S. Jack I learned about on this forum, it does not have a cross member, it is open on the end.. The cross member on the yellow jack (on the front wheel end of the jack)hits my Jiffy stand when the stand is down, so I have to sit on my bike, roll the jack under the bike, than hand pump the jack up; what a balancing act. When lowering, I hope to remember to put the Jiffy stand back down again. If you have a 2007 Street Bob you must use H/D frame extensions, due to a oil pan guard, other models "may" have the same need for frame extensions.
Old Apr 14, 2007 | 08:52 AM
smoknwrenchs's Avatar
smoknwrenchs
harbor freight real good jack and only 49.00 on sale
Old Apr 14, 2007 | 11:14 AM
FXST06's Avatar
FXST06
I use the yellow Sears jack. Held my Softail Std. up all winter and lowered it fine.
discodave
Feb 6, 2013 08:04 AM
larryHD956
Sep 27, 2012 12:52 PM
Nipdawg
Sep 6, 2012 03:34 PM
DHart
Feb 26, 2010 05:06 PM
IndyRider
Jul 13, 2006 07:08 AM
