Help very confused
Old Jul 26, 2005 | 09:18 AM
Curly61's Avatar
Curly61
Default Help very confused
I have a 2004 883 XLC with approximately 4900 miles on it . I am having some very bizarre problems now . I can be riding at 55 mph and then jump off the exit and come to a stop light . When this thing idles down it just wants to die like it is starving for gas starts popping and spitting and I have to pull to shoulder and just let it idle until it finds itself then I can go again. First my taxes have been paid . I have a 045 slow jet and a 180 main with the fuel screw out exactly 2.5 turns. Screaming eagle air filter and SE 11 pipes and up until now have had absolutely no problems . Plugs read good burning about Tan colored . I recently installed new plugs thinking I had bad plugs but still have this problem . So I just accessed the diagnostic codes and have a code P0374 or something like this it means Crankshaft position sensor . Could this be the problem ? Since I am the second owner the warranty does transfer to me if the part needs replaced . Just not sure . I also replaced the round intake gasket thinking I had a vacuum leak and it is sdtill doing this . Once i get it moving it seems to be fine . Just completely puzzled now . Any suggestions ?
Curly
Old Jul 26, 2005 | 09:34 AM
HDF Tech's Avatar
HDF Tech
Default RE: Help very confused
The P0374 code that you have relates to the crankshaft position sensor. Barring any other problems like broken/disconnected wires, I would say to replace the sensor. They do go bad.
Old Jul 26, 2005 | 09:54 AM
Curly61's Avatar
Curly61
Where exactly would the sensor be located . I can probably slip outside at lunch and check the wires . I appreciate the advice I really do not want to have to take the bike to the shop and be without it for a couple weeks . they are always so so busy .
Old Jul 26, 2005 | 10:17 AM
HDF Tech's Avatar
HDF Tech
Not exactly sure on the sporty but on the big twin it's located up by the oil filter, you hit it with the filter wrench when removing the filter. Try a post in the sportster section , maybe someone there can verify this for you.
Stanleylo
Jul 14, 2017 01:44 AM
0734
EVO
Sep 26, 2014 09:04 AM
JRK5892
May 3, 2013 11:09 AM
04883c
Sep 22, 2010 05:17 PM
satocita
Jun 15, 2009 11:18 PM
