squeak from throttle grip
Old Mar 15, 2012 | 07:34 PM
ironmike666's Avatar
ironmike666
Default squeak from throttle grip
Went and bought a set of joker machine grips and a throttle sleeve. Now I have a squeak coming from the grip. And besides that its scarring up the handle bar beneath it. I tried putting a little grease in there, but no luck. Probably just a poor quality product or is there maybe another explanation? Help
Old Mar 15, 2012 | 07:43 PM
Gliden's Avatar
Gliden
Do you mean the throttle part of the grip that gets incased in the switch housing is rubbing ? Or the side of the grip is rubbing against the switch housing on the outside?
Old Mar 15, 2012 | 07:47 PM
ironmike666
No, the part that gets incased but its the inside of that...you can see the scratches on my bars from it.
Old Mar 16, 2012 | 04:16 PM
Gliden's Avatar
Gliden
Wow . So your actually binding or rubbing the inside of the grip that slides over the bar the part of the grip that gets incased in the switch housing?
Old Mar 16, 2012 | 04:23 PM
Gliden's Avatar
Gliden
That's got to be a machine shop issue where they messed up on the bore size of the grip.
You could probably go to a local machine shop and have them bore you out a thousandth but your gonna go nuts once you start to feel the lack of smoothness due to it chewing up your bar.
Let me know how you make out. My pm grip had an issue where they pressed the end plastic that rides in the end of the grip too far in the grip and it caused the metal grip to rub up against the switch housing scratching it and finally binding the throttle open when I let go. Damn near killed me. Pm fixed it.
Hematite
2014-2024 Touring Models
23
Aug 6, 2018 11:09 AM
geost
Dec 27, 2014 08:36 AM
14bob
Feb 28, 2014 10:00 AM
TennesseeMustangPerf
Sep 24, 2011 02:15 PM
SM49
Feb 5, 2008 12:42 AM
