Starting problems
Old Mar 3, 2013 | 04:49 AM
anges sombres's Avatar
anges sombres
Stage II
Default Starting problems
Hiya there where to start with my intermittent problem
bike.....2009 Fatboy staged to 1690
problem.....will fire on first touch of starter button 9 times out of 10 when cold
.....will fire occasionally but seems laboured with a grounching noise when hot
.....when refuelling and engine hot struggles to start with grounching noise and also forces fuel out of vent pipe onto floor
.....if allowed to cool starts again 9 times out of 10
Replaced battery and checked charging system ok spark plugs leads and coil all seem ok , without going through swap a part routine was wondering if anyone had heard of similar problems and cold give me a tip or two
thanks paul
Old Mar 3, 2013 | 06:50 AM
gunnerchevy's Avatar
gunnerchevy
I have a 08 fatty with extensive motor work done. I had the same problem and the fix we did was when motor gets hot it will shut down a cylinder and dump fuel in to cool and refire it only does this at stops example. Stop lights etc once this was programmed in i have not had anymore problems firing up hot or cold.
Old Mar 3, 2013 | 12:08 PM
anges sombres
Stage II
hi I only have the problem when the bike is switched off then trying to restart it hot
Old Mar 3, 2013 | 12:17 PM
Scaredofrain's Avatar
Scaredofrain
Vapour lock in fuel line. Can that happen with the FI models?
hotdotdog
Electrical/Lighting/Alarm
Oct 24, 2023 05:26 PM
jason bennett
Apr 28, 2018 07:22 AM
scotsport
Sep 22, 2013 05:47 PM
i Confederate i
Panhead
Sep 7, 2013 10:31 PM
slickmyster2004
Jul 5, 2009 06:49 PM
