Torx Sizes Question
Old Apr 22, 2013 | 07:52 AM
RavenBlack's Avatar
RavenBlack
Default Torx Sizes Question
I have a Service Manual and the Parts Manual and can't figure out what Torx sizes to use on different bolts.
Example: Part# 3880 reads "SCREW, 1/2-13 X 2-1/4 TORX recessed button hd."
This does not say the Torx size to use? is there a way to figure this out? In the manual it will sometimes list the exact Torx size to use but not always.
Any help would be appreciated.
Old Apr 22, 2013 | 07:59 AM
djaudette's Avatar
djaudette
Not sure, but I know you will need T27. This is the only size that does not come with the purchase of a torx set, yet it is the one needed most.
Old Apr 24, 2013 | 12:37 PM
Nagy's Avatar
Nagy
6th Gear
DJaudette is correct, the T27 is necessary for a Harley. There are sets that include it, but you will need to look specifically for them. I just bought a rachet drive set at Lowes for about 25 bucks that has it. I do not know what year/model you are working on, but for general purpose stuff, You should have T15,T20,T25,T27, T30 and T35 around at a minimum. Electronics and PCs use T9 periodically, as well.
Old Apr 24, 2013 | 08:30 PM
Jbarr's Avatar
Jbarr
Used a T45 the other day taking off the Sissy bar.
Old Apr 24, 2013 | 08:33 PM
Harleycruiser's Avatar
Harleycruiser
If it wiggles at all it is too small.
Old Apr 25, 2013 | 02:17 AM
dbc58's Avatar
dbc58
That's what she said.
Old Apr 25, 2013 | 02:35 AM
ynots's Avatar
ynots
A sure way to figure it out is buy a whole set (with T27) and size the fasteners up as needed. I recommend a 3/8 drive set that can be used on a torque wrench
Old Apr 29, 2013 | 01:48 PM
grbrown's Avatar
grbrown
RavenBlack, give us a clue! Where is this screw used? We can help you better with some more info.
The sizes I use on my bike (which has a mix of parts from many years) are: T10, T15, T20, T27, T40, T45.
Whut24
Jul 30, 2020 12:31 PM
dynafan68
Oct 19, 2009 03:01 PM
CMC
Nov 21, 2007 05:58 PM
tmitchellof PG
Nov 17, 2007 08:40 PM
MikeO
May 10, 2006 04:45 PM
