Tool Kit For The Road
Old Aug 18, 2005 | 05:35 PM
HDF Tech's Avatar
HDF Tech
Default Tool Kit For The Road
With todays bikes, there are some things that you can repair on the road, but most things being electronic are best left to a professional. Below I'll try to give you some of the things that would be usefull for a tool kit for the road in case of a breakdown.
A multi tip screwdriver (2 in 1) phillips and regular on the tips.
Spark plug wrench.
Pair of vice grips 6"-8" Or Channel lock pliers.
Set of torx bits (just the bits) preferrably ones that will fit into the multi tip screwdriver handle.
A multi tool of allen keys.(6-10 piece set in one tool).
Small set of 6 point wrenches.
Small 3/8 drive socket set, if you have the room.
A 6' adjustable wrench.
Tubeless tire repair kit with inflator.
Spare fuses.
Pair of cutting pliers (side cutters).
A length of plastic tubing for "borrowing" some gas.
A dozen or so nylon zip ties.
Electrical tape.
Some assorted bolts and nuts.
A few different size hose clamps.
A few feet of safety wire to get you home if a cable breaks.
Emergency repair barrel for the clutch cable(has 2 screws that clamp the cable for a temp repair).
A 12 volt test light.
A small flashlight that works.
Some rags to clean up with also a tiny spray can of WD40 to use as a hand cleaner or a lube.
Most important is a cell phone when you find out you can't fix it.
Sounds like a lot but will get you through some of the smaller break downs.
K9Tamer
Jul 8, 2012 03:56 PM
Tvol
Mar 13, 2011 01:27 AM
mrbuck
Mar 20, 2008 05:25 PM
someday69
Mar 16, 2007 03:22 PM
Arizona
Exhaust System Topics
Dec 31, 2006 01:22 PM
