Apes slipping at the clamp...
Old Feb 23, 2007 | 10:29 AM
BlessedHellride's Avatar
BlessedHellride
Default Apes slipping at the clamp...
Anybody out there with apes have a problem with them slipping, forward and back,at the clamp? It is tightened as tight as I can get it, but it still slides with some good force, which can be applied unknowingly at times. Can something be put there to make it grab better?
Old Feb 23, 2007 | 01:07 PM
rh8234's Avatar
rh8234
Default RE: Apes slipping at the clamp...
remove top clamp. position bars by hand where you want them. mark bars and lower clamp (risers). drill into riser for a doll pin. drill thru bar for the pin. install pins in the risers so it sticks up enough to go into the holes you drilled in the bars. install bars onto the pins. replace top clamp.
Old Feb 23, 2007 | 01:13 PM
anubisss's Avatar
anubisss
Are the bars knurled?
Old Feb 23, 2007 | 05:17 PM
BlessedHellride
Yeap. knurled. I'm gonna try that tape you mentioned in the other thread.
Old Feb 23, 2007 | 05:20 PM
fxstcguy98's Avatar
fxstcguy98
First loosen all the riser bolts and put it back by alternating a few turns on each bolt until tight. If that doesn't work, get some thin lead sheet (like 1/16" or so) and cut two small strips wrapped around the knurled part of the bars and tighten it all down agian.
Old Apr 7, 2007 | 10:44 AM
st john's Avatar
st john
I use shim stock.
Saint
Old Apr 10, 2007 | 06:02 AM
Oldtimer of NM's Avatar
Oldtimer of NM
Wrap strips of aluminum cut from a beverage can around the bar inside the clamp.
Old Apr 11, 2007 | 09:00 PM
m.breen's Avatar
m.breen
Sometimes I use pieces of old bicycle tire tubes to tighten things up. May or may not work for handlebars.
Old May 7, 2007 | 10:10 PM
lsalem103's Avatar
lsalem103
1st Gear
try a couple of drops of red locktite on the knerled part of the bars then tighten down the clamp don't get any on the bolt threads or the bars will become perminent
Old Jun 2, 2007 | 06:18 PM
mean machine's Avatar
mean machine
6th Gear
i have the same problem on my 07bob ,i'm going for my 1000mile change i'll speak tp the dealer about it.
