Where is the "Best Air Cleaner" thread?
SE Ventilator cause I like the way it looks and I already have it installed. With the K&N filter, flows 287CFM which is fine for the heads I have which flow 252CFM
(2) Dorman 785-410 1/8" MNPT - 1/4" hose fitting (advanced auto)
(10') 1/4" vacuum line (advanced auto) yep plenty left over.
(1) 1/4" vacuum hose "T" (advanced auto)
(1) 1/4" to 3/8" vacuum hose adapter (advanced auto)
(1) Spectre 3991 Breather Filter (advanced auto) http://shop.advanceautoparts.com/p/s...m=spectre+3991
total - $15.49
took the backplate and drilled 25/64" holes in it
The I used a tap, M10x1.25 to thread the holes
The I cleaned the breather holes and oil drain holes thoroughly with brake cleaner
Then I siliconed the oil drain holes that go back into air intake (yep that was the only color hi-temp/oil resistant silicone I had on hand.
The I screwed in the fittings, attached hoses, attached clamps, inserted "T" in proper location, ran the hose inside the front pushrod tubes, drilled out the head bolts to 1/8" all the way through, and located the filter just behind my oil cooler below and fastened in place with a zip tie.
all said and done, $16 in parts and about 45 minutes of my time that will prolong the life of my motor.
Now if I could just figure out how to get all the crud off the top of those pistons without pulling the heads off, I'll be a happy camper...
PS. The "wetness" you see is from my cam and head change earlier in the week.
P.S. I wonder if a Vtune run would show a difference after your mod...
I will tell you although I wouldn't expect to see much if any difference there in the VE tables.
total - $15.49
The I screwed in the fittings, attached hoses, attached clamps, inserted "T" in proper location, ran the hose inside the front pushrod tubes, and located the filter just behind my oil cooler below and fastened in place with a zip tie.
You can clean your pistons of that carbon build up without pulling the heads by feeding some water into the intake while running the engine...another old trick is automatic transmission fluid.
On the VE tables, it depends on how much hot oily your umbrella valves are passing. You may see a small change. As time goes by and carbon builds up, there will be more of a difference.
Also, important is that even with the same volume of air in the combustion chamber, if some of it is exhaust from internal breathers, this is oxygen depleted air and will not produce as much power as air coming from outside that has a higher oxygen content.
Again, very nice external breather system you built!
DKCustomProducts.com
