Where is the "Best Air Cleaner" thread?
There are many, many threads on the subject.
There are just as many opinions.
Here's a pretty good thread on the subject-
https://www.hdforums.com/forum/sport...ce-intake.html
DKCustomProducts.com
Stock football cover and stage 1 HD air cleaner kit with K&N air filter properly maintained is good up to about 115HP.
The rest is simply what you prefer to look at.
The best looking is completely subjective.
The best functioning is objective.
As long as it flows enough air, filters out the dirt, and does NOT put hot oily air into the combustion chambers, it is going to be better than almost all the aftermarket air cleaners out there that do feed the oil into the intake, per EPA regs.
Here's a pic of the typical carbon build-up in an engine running the popular "air cleaners"
that are "Stage 1"
Here's a pic of an engine with 5k miles on it that is running a Better air cleaner, one that does NOT feed oil into the combustion chamber.
Check out post #28 in this thread- https://www.hdforums.com/forum/dyna-...estions-3.html
With respect, all air cleaners do not function the same, with only a difference in looks. HD engines run best with cool air and gasoline, they do not run as well when you add hot, oily, oxygen depleted air from the breathers into the mix.
couple of weeks ago, I changed my heads with 13k on the clock. The pistons were about as black as black can be with carbon and oil buildup.
So I cleaned them up with WD-40 and a razor blade before installing new heads. This is what they looked like afterwards.
fast forward a couple of weeks to Tuesday of this week. Ever since the head install I found myself tracing down this very irritating "ticking". Another story for another day. So instead of pulling heads, I decided to go down to Home Depot and pick me up one of those borescope cameras (one of the best damn inventions I've seen to date) to take a peek inside and make sure it wasn't a valve hitting the piston. What I found with 225 miles on the clock since cleaning those pistons was horrifying to me. Looked exactly like the image I posted above after 225 miles!!!
I have to throw my
I have to throw my
You can see his original post and his engine specs in his signature here- post #28
I have spoken to him before using his pic, he assures me he did not even wipe it down after pulling the heads at 5000 miles.
On your typical HD, with the typical cruiser style riding, when running external breathers, there will be some discoloration on the pistons, but no significant build up...that nasty stuff you saw on yours is not from air and gas, it is from oil being fed in via the air cleaner, courtesy of the EPA.
