2009 Heritage softail classic wont start.
Old May 23, 2014 | 11:53 AM
dylan42's Avatar
dylan42
Stage IV
Default 2009 Heritage softail classic wont start.
Hey everyone I am new to the forums. My father bought a salvaged 2009 Heritage Softail Classic. We rebuilt got everything on we just got the fuel tank back yesterday from getting paint. We got everything all together put fresh gas and oil in it went to start it up and it turns over but will not start up. We checked the plugs and its not flooded. Any ideas would be appreciated. Thanks.
Old May 23, 2014 | 11:56 AM
dylan42's Avatar
dylan42
Stage IV
My father thinks that it's not getting any gas because the plugs are not even wet. But we are unsure what to do.
Old May 23, 2014 | 12:00 PM
Uncle Chester's Avatar
Uncle Chester
Are you getting a spark at the plugs, is the fuel pump priming, have you checked all the sensors like the crank position and IAC? Could be a number of things on a salvaged bike depending on the damage it took.
Old May 24, 2014 | 10:00 AM
dylan42's Avatar
dylan42
Stage IV
It is getting a spark and we think the fuel pump is priming kind of sounds like bubbling? Also it took front end damage, is it possible when we had the fuel tank redone maybe some sort of wiring issue or hose problems?
Old May 24, 2014 | 10:09 AM
rooti's Avatar
rooti
The fuel pump, the fuel pump relay, or the fuel hose inside the tank has a crack or hole in it. If you fill up the tank it will probably start but then you have to drain the fuel back out to replace said items.
Old May 24, 2014 | 11:26 AM
Uncle Chester
What rooti said. Bubbling is not a sound the fuel pump/system should make.
Robby999us
Jun 28, 2017 10:25 PM
blues88
Jul 6, 2016 06:38 PM
newways
Nov 15, 2012 07:43 AM
DynaDawg09
Jun 30, 2012 08:00 AM
PTAG
Sep 28, 2009 08:45 AM
