Do I have a problem?
Old Sep 27, 2009 | 10:55 PM
PTAG's Avatar
PTAG
Default Do I have a problem?
I posted this in the softail forum also but since I have both a Bagger and a Heritage I thought I would look for help here also.
Here is my problem:
I have a 2009 Heritage. It always takes several seconds of starter to start. My 2009 bagger starts up in less than a second. The dealer said this was normal, like they always say, but said it could be a variance in the crank case sensor. I switched the bikes crank case sensor and it did the same thing so I know it's not that.
If I let it sit over a week I ride my Ultra Classic more) it takes even longer to start like it's starving for fuel. Kind of like a choked carb model. Anybody else see this or do I have a problem like a fuel pump not pumping up or? I am waiting for the light to go out and the pump to stop.
Thanks for any help.
Old Sep 28, 2009 | 07:18 AM
FLHTCU Owner's Avatar
FLHTCU Owner
PM or reach out to DAWG and see if he can diagnose the issue for you.
Old Sep 28, 2009 | 07:38 AM
smokindave's Avatar
smokindave
Do you have a PC-V on it? If you do, use this start sequence......turn on ignition and immediately hit start button, works every time. Some of the aftermarket fuel management systems will interfer with the stock ECM for the starting sequence.
Old Sep 28, 2009 | 08:45 AM
PTAG's Avatar
PTAG
Both my bikes have a PCV's and only the Heritage does that. I will take your sugestion and try that this evening. I'll let you know what happens.
dylan42
General Topics/Tech Tips
May 24, 2014 11:26 AM
Ironpony1
Jun 24, 2012 04:43 PM
Splais1
Exhaust System Topics
Oct 28, 2010 01:23 PM
PTAG
Oct 2, 2009 10:15 PM
irlm1
Jul 8, 2006 04:21 PM
