Hawg Wire vs. Biketronics
Old Sep 14, 2009 | 07:46 PM
iceman5218's Avatar
iceman5218
Default Hawg Wire vs. Biketronics
I know which one I'm getting but was wondering what the difference is in the wiring harness that hooks up the controls to an aftermarket radio. Specifically the Pioneer p5100ub.
Old Sep 15, 2009 | 04:09 AM
EricW's Avatar
EricW
Here's how the Biketronics looked on mine with a Sony. Same type pigtail I would think. I am really happy with the Biketronics. Toured their biz and met the owners/managers before I bought. Great people and very helpful. EW
Old Sep 15, 2009 | 07:26 AM
todd-67's Avatar
todd-67
I am not 100% on this so someone correct me if I am wrong.
I thought the main difference between the two setups is that biketronics harness is pre-configured for Sony radios while the hawg wired setup has you tap into the harness on the radio yourself freeing you up to use a wide range of radios. Both plug into the factory harness to get the hand controls on the bars to work.
Old Sep 15, 2009 | 08:27 AM
iceman5218's Avatar
iceman5218
I guess my real question should have been, Do they work off the IR signal like a remote or are they hard wired.
Old Sep 15, 2009 | 08:42 AM
Harleypingman's Avatar
Harleypingman
Much better question. They are both hard-wired. Both connect to the base audio connector that formerly plugged into the back of the HK headunit, then are hard-wired to the compatible headunit.
Old Sep 15, 2009 | 10:16 AM
IceHeritage's Avatar
IceHeritage
The Biketronics has AV (Auto Volume), i have it hooked up to my Alpine System
Old Sep 15, 2009 | 05:21 PM
iceman5218's Avatar
iceman5218
Is the auto-volume that big a deal or just something u get use to?
Old Sep 15, 2009 | 06:44 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Before you buy the Hawg Wired setup you need to check out the BT480: Titan - 180 watts per speaker amp that Biketronics has. The biggest setup Hawg Wired has is 75 watts per speaker.
I've had both and gave away my Hawg Wired setup. Of course changing out the stock HK radio will be a big plus for you.
Check out my thread here https://www.hdforums.com/forum/touri...o-problem.html
Bitketronics lifetime Warranty
Hawg Wired Warranty ???? I tried to find it for you and couldn't.
Old Sep 15, 2009 | 06:49 PM
refuzeandrezizt's Avatar
refuzeandrezizt
For those that have installed the Biketronics kit, if any, how hard is the install? I just bought a 2008 EG Standard and will be buying the complete kit. From what I understand, it includes everything I need and the install is pretty easy. How about the internal antenna? Does it work at all?
Old Sep 15, 2009 | 07:08 PM
riteway's Avatar
riteway
Biketronics plug and play,VERY happy with my unit on my 04 flht with hogtunes but lookin forward to an amp and speakers(6.5)when OBAMAECONOMICS Kicks in....For now ROCK AND ROLL never sounded better....AND YES auto volume is sweet...Beats turning doun radio at a stop to hear yourself think....LOL....
As far as antenna...Well mine is a autozone power unit..its ok close to station base but in boonies forget it....id like better reception and i think guys have had good luck with other ones,you might search it .....we all live in different areas so some stations come in stronger...
