drive belt adjustment?
So how much twisting torque should ya use when twisting the belt? Bubba the gorrila fingers should have no problem twisting the belt a couple rotations while Sherman the key board commando has trouble twisting the same belt 10 degrees from flat. You noted to twist it until it gets tight. What is the definition of tight?
This is why they make the calibrated tool to do this adjustment.
Dale_K
Jul 8, 2011 06:43 PM
