91 sportster vibration
Old Jul 25, 2014 | 06:01 AM
SPORTSTER91's Avatar
SPORTSTER91
Stage IV
Default 91 sportster vibration
I have a 91 883 with a vibration in every gear. It all started when i was pulling a hill and geared down and the vibration came in it. Now every gear you shift it vibrates and over 50 mph the vibration hurts your hands and feet. The bike has a lil over 15,000 on it so im not sure if its the clutch or something internal. If someone could poiint in the right direction i would appreciate it. Thanks
Old Aug 1, 2014 | 02:53 PM
mjremington's Avatar
mjremington
5th Gear
I've got an 02 1200 Sporty. I get pretty bad vibrations from it no matter what really. Any Sportster pre 05 is a solid mount motor set up and it causes the vibration of the motor to resonate to the pegs and bars. 05 and newer are rubber mounted making the vibration much less annoying. Not sure if your new to the bike or if this has just now become an issue but that's the best explanation I've got for you.
Old Aug 1, 2014 | 02:58 PM
mjremington
5th Gear
And if it's a new issue, I wonder if something loosened up on you like a motor mount?
Old Aug 6, 2014 | 01:19 PM
ClodeV's Avatar
ClodeV
Lets start simple so you dont spend a ton of dollars. check both your wheels for your wheel weight. I had a set go out on me this year. Next check all your motor mounts are nice and tight. After that you'll need to dig in a little. look at your front final drive is on good and tight. Take the clutch side cover off and make sure no teeth are missing from the basket. At this piont go see a mechanic i'm outta ideas. willing to bet you tossed a few wheel weights.
NO PCKL
Jan 24, 2019 08:23 AM
darylnj
EVO
20
Oct 21, 2014 09:15 PM
hall1836
Jun 26, 2013 12:15 AM
scooter 7
Dec 28, 2012 08:16 AM
lou1
Nov 16, 2010 04:10 PM
