tc88b upgrade
Old Aug 16, 2014 | 12:46 AM
eastcoastink's Avatar
eastcoastink
5th Gear
Default tc88b upgrade
I'm looking into upgrading my stock 88b to a S&S 106" with a S&S Super e carb. Do I need to change any cams or any other parts to help compensate this increase?
Old Aug 17, 2014 | 11:05 AM
grbrown's Avatar
grbrown
S&S don't make a 106" kit for that engine, unless you also intend changing the crankshaft, but they do make 95/97/98" kits. You will get more performance for your investment if you change cams as well. If you plan doing this work yourself it sounds as if you should find yourself a local S&S stockist and talk through with them what you want of your bike. S&S make several suitable cams and matching them to CR plus one of their kits is something you will be wise to work through with a suitable tech.
Old Aug 17, 2014 | 02:51 PM
fidel's Avatar
fidel
bore ur cylinder and buy piston for 98 ci add a cam for ur riding style and an ignition module to adjust timing like the daytona twin tech or an ist from s&s self adjust
Old Aug 22, 2014 | 03:41 PM
eastcoastink
5th Gear
thanks for the replies. I did find out that the company had the fitment listed wrong. they have since fixed it. The 106'' is from '07 and up. looks like i'll be shooting for a 98".
grbrown
EVO
14
Dec 13, 2014 08:35 PM
Good_Apollo
Feb 4, 2011 09:31 AM
Jeffro1964
Jan 16, 2011 08:26 AM
SpyderTB
Exhaust System Topics
Nov 6, 2009 09:59 AM
Meathooks
Jan 23, 2006 07:53 AM
