Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Cargo Trailer Mods?
Old Sep 23, 2021 | 06:18 AM
JHC210's Avatar
JHC210
Default Cargo Trailer Mods?
I recently purchased a 6x12 v-nose cargo trailer to haul my SGS. I am interested to see how others have built out the inside. I have painted the inside walls already and adding a textured deck paint to the floor. Additional mods include adding the wheel dock chock, e-tracks, strap holder and maybe a cabinet. I am looking to add additional lighting inside but still figuring out that.
What have others done?
Old Sep 24, 2021 | 09:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I installed E tracks along each side on the floor, about 6 inches from the wall.
Make sure the e track screws go into the metal floor supports.
I also installed e tracks on the side walls to use when hauling stuff like furniture.
I have a 6x12 V nose (built by Bravo Trailers).
Wheeldock chock.
If you have E tracks in the wall, you can use fixtures that will hold 2x4s to build a shelf that can go from the rear of the trailer all the way forward to the side door, above the motorcycle.
I used it configured with the shelf when I was moving all my stuff.
I just snap a couple of ring fittings into the wall e track and hang all my straps on them.
Remember to position the wheeldock so that the position of the bike will put at least 10% if the trailer weight on the front.
The best way to check this is to use the "Cat" scales at a truck stop, there is an easy process to do this, if you want I can make a separate post for the process.
The aluminum slider plate on the floor to cover the space between the ramp door and the floor is the best money you will spend.
Trailer floor plate.
E track hardware
Frame mounted tie down Frame mounted tie down
Old Sep 24, 2021 | 10:10 AM
Keggr's Avatar
Keggr
I used mine to camp at Buffalo Chip for a few years, as well as hundreds of weekends at various road racing tracks throughout the US.....
Insulated top and sides with R30, then added 1/4” white fiberboard internal walls, diamond plated about 16” up from floor inside, checkerboard vinyl tiled the floor, put floor to ceiling cabinet with shelves, a small sink with a water connection outside and a mini fridge with ice maker, microwave, wall mount TV and a self contained portable John, added a 30Amp receptacle to the outside with a marine grade 30A twist lock extension cord, led rope lights around the ceiling corners with a dimmer, Carrier roof mount AC/Heat unit.....The hardest part was reinforcing the roof for the AC Unit weight. Basically it was a sleeps two camper.
It was a 14’ Rance Renagade dual axle with a long V (4’ deep V) sloped nose and an extended tounge.....Served me well for about 15 years until I sold it.
Due to the deep V, I could get two full baggers in, or 4 race bikes.....
Ahhhh.....the good ole days.
Old Sep 28, 2021 | 08:16 AM
hooter57's Avatar
hooter57
Default Cargo trailer mods
I figured the nose was mostly wasted space so I built a bench. Pretty tight with the bike loaded but still useable.
Old Sep 28, 2021 | 09:41 AM
strych9's Avatar
strych9
Mine is a 7x14, but I put down three rows of e-track on the floor. Painted the walls and floor. I'm going to add some e-track for the walls for tie-down storage, and some anti-skid tape on the ramp. I have two staggered Condor chocks mounted solid, and have an e-track adapter so I can mount a chock on the center track for single-bike hauls. I had support plates custom made for everything that bolts to the floor, and added a diamond plate cover for the ramp gap at the top.
coryhdwg
Nov 21, 2018 06:39 AM
JimGnitecki
General Topics/Tech Tips
82
Jan 4, 2018 10:58 PM
Sapman
Oct 26, 2014 07:41 AM
primdl
Feb 26, 2008 07:11 AM
Qball
Sep 14, 2005 01:26 AM
