Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
I think the transmission shafts are the same part numbers for all the tapered mainshaft units.
The big difference between the early and late was the trap door and the clutch release, the `86 and earlier used the clutch release arm on the trapdoor, the `87 and later use the ball and ramp system.
Maybe you just need to change over to the later model trap door and clutch release.
