Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Heat source has moved
Old Apr 22, 2010 | 08:15 PM
  #31
coupe55's Avatar
coupe55
Default ????
Originally Posted by 62hdbiker
So what is the consensus here? Heat sheilds on for scooping air or off so air is not trapped around motor while sitting in traffic?
Does wrapping the header pipe to keep heat in the pipe and increase exhaust gas velocity cause the motor to run hotter or have little effect on motor temp and just help rider temp? at 88 deg. I have seen 240 in stop and go creeping traffic. My ETMS was cutting in some times.
I am tickled to death with 240 and the EITMS does not kick in at these temps, kicked in last year close to the 285-290 mark. I would be suspect of the oil temp gauge accuracy, you did not do the old oil line connection as the older gauges instructed that reads oil tank temp instead of putting the sensor in the oil pan where you get a more realistic temperature reading?
Wrapping the header may keep a little heat off the right foot, without removing the cat stuffing I fail to see how it would effect the idle tempertures!
Old Apr 22, 2010 | 08:21 PM
  #32
62hdbiker's Avatar
62hdbiker
My sig says NO CAT. The sending unit is in the oil tank. The EITMS is sensing head temp.
Old Apr 23, 2010 | 03:19 AM
  #33
msocko3's Avatar
msocko3
With fuel management and the cat gone you should be able to go without the heat shields. I've never studied heat wrap and its affects on exhaust velocities. There is going to be a fine line with heat management and stop and go traffic. With a stock engine using fuel management your only going to be able to go so far with heat reduction. It will be leaps and bounds better than how it comes from the factory but still it will warm up and the EITMS will kick in when you start hitting stop and go in warm ambient temp.
Old Apr 23, 2010 | 07:02 AM
  #34
62hdbiker's Avatar
62hdbiker
Thanks m3
Old Apr 23, 2010 | 07:34 AM
  #35
Mr. Wizard's Avatar
Mr. Wizard
Heat wrap is similar in its effects as a coated pipe. Your pipe, when warm, will flow hot gases better than through a cold pipe thus better velocity but the exhaust gases will heat up the pipes rather quickly. Another fine line is...how much heat you want to keep vs how much heat you want to dissipate which will allow heat to escape to your leg.
Take Stainless vs steel vs coated steel. Stainless will lose heat very rapidly but where does that heat go, to your leg? Steel will hold heat yet continually radiate heat to your leg well after the bike is turned off. Coated steel will hold heat yet you can touch the coating within a few minutes after you shut down your bike.
Mix these issues with the air flow dynamics of a trike and your options become limited thus additional manual preventions come into play such as your external oil cooler and electrical jug fans.
Bottom line observation... a trike is going to get hot during high ambient riding and low MPH cruising. You can only help this condition by the above remedies including lubricants, proper tuning and flow dynamics.
just my .02
-wiz
Old Apr 23, 2010 | 08:00 AM
  #36
62hdbiker's Avatar
62hdbiker
just my .02
-wiz
So, do I wrap to keep heat in or SS to radiate heat? Is wraping hard on motor?
Old Apr 23, 2010 | 08:19 AM
  #37
Mr. Wizard's Avatar
Mr. Wizard
Again, just my .02
Like M3 my experience with wrapping is limited although I have tuned several bikes with the wrapping and the heat radiated from it was low.. but it's flat out fugly. I would not put wrapping on any of my bikes...Yes, you can cover it with your chrome shields to hide it but I still know it's there. Wrapping isn't hard on a motor just hard on the eyes.
A stock head pipe for a 10 TG has a cat as we all know. What pipes are you running and/or how did you remove your cat? Answering your question from above would depend on the rest of my answer.
Old Apr 23, 2010 | 09:32 AM
  #38
coupe55's Avatar
coupe55
Default Im Cool
With the mods I've done to date I am satisfied with the engine temps at idle, even on hot days in traffic. Have just had one 89 degree day so far in traffic but idled over 10 minutes at one stop! I will hit higher temps in July and August but am satisfied the engine temps at idle are going to be within safe limits.
I have only one more observtion and that comes from the Harley Owners Manual that comes with the Tri Glide. Page 204 in the troubleshooting section: Overheats, 1. Insufficient oil supply or oil not circulating. 2. Heavy carbon deposit from lugging engine. see dealer. 3. INSUFFICIENT AIR FLOW OVER CYLINDER HEADS DURING EXTENDED PERIODS OF IDLING OR PARADE DUTY.
Yet MOCO techs will tell you the Trike's don't run hot. It is obvious most of us even in rural settings will have to be in city traffic conditions at some point but this is Harley telling you not to go downtown in hot weather. I notice a large city just went from Harley to BMW bikes for their police bikes, 4000 units. If you have to maintain them in urban area's it is obvious Harley is not the best choice anymore.
I believe they can still take the summer idle conditions or parade duty. Harley will sell you a premium oil cooler and a parade fan that gets you closer to something usable in city driving conditions. They really should come as standard equipment on the Tri Glide, my dealer tech told me this when I was first complaining about the high temps at idle. Of course they would rather sell them to you out of the accessory catalog after you make your initial purchase. Off the record he also told me I needed to dump the main source of the heat, Harley techs have been put in a complicated situation with the cats also.
Old Apr 23, 2010 | 11:30 AM
  #39
62hdbiker's Avatar
62hdbiker
Again, just my .02
I have an 09 dresser head pipe that I welded the turn down section that I cut off my pipe. I have PC5 with auto tune set mostly at 13.5 to 13.7.
The wrap is ugly-but I painted it black with hi-temp paint and put the heat sheilds back on. You can barely see it.
It is much cooler comfort wise.
Old Apr 23, 2010 | 11:56 AM
  #40
Mr. Wizard's Avatar
Mr. Wizard
thanks.. I remember now.
If you are happy with the PCV w/auto and it does a good job for mileage, performance and temperature then you've done about all you can do with the exception of what was discussed above... ie, fan and so on.
You could also install a better cam than the smog cam you have now such as the 255's or an Andrews 26H which will give you more lower torque... you could do a bore and go up to 117 and flow your heads like some of the guys here are... it's all subjective to your personal preferences and riding habits as well as your pocketbook.
If you went with a new head pipe set up you would experience a little more throttle response too. Since Jamie is about the only one that makes the complete set up for a TG I would not condemn it because it is stainless steel, you also don't have to run his mufflers but others here seem to be happy with them. Some of the best exhaust systems around are stainless but they are not near your leg with the aerodynamics of a trike body.
You could call Fullsac and get his X Pipe that is coated and weld an extension on like you did before.... again throttle response would be better and since it is a steel coated pipe it will run cool yet retain interior heat where its needed....
There's no common answer to a trike's heat issues and no single magic pill for a one-fits-all. I took a 24K Ultra and poured another 20 grand in her to fit my hobby and am happy with it but if asked if I would do it again, the answer would be no. If asked if I would purchase a TG and pour another 5 grand into her so she could breath, maybe... but there would be another 5 grand for bling... the disease just doesn't stop until you finally say no.
again, just my opinion
