Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Trailer hitches
Old Oct 21, 2010 | 11:02 AM
spider2's Avatar
spider2
Default Trailer hitches
What hitch out there is the hidden hitch with the 1 1/4 tube. Hidden to me means you can see the receiver when the ball part that slides into the receiver is not attached. Also would need the isolation wiring harness for a 4 wire flat trailer plug. With this type of hitch, do you have to remove the hitch to get the rear wheel off?
Old Oct 21, 2010 | 08:51 PM
800XC SP's Avatar
800XC SP
mchitch?
www.mchitch.com
if that's the one you don't have to remove it to take the wheel off
That's what I have on my SG...
Old Oct 22, 2010 | 05:19 PM
0734's Avatar
0734
A hidden hitch IS one that cannot be seen with the draw-bar removed. It can be installed on the trike frame members and will certainly not have to be removed to take a tire off, or vice-versa. Most trike and MC receiver hitches are indeed 1-1/4 inch, but you can get or make a 2-inch if desired. One good one is mentioned above, but you can make one on your own a lot cheaper, if you are mechanically inclined to do so. You can get plug-n-play adapters or simply wire your trailer for a 5-pin flat. Harley uses a separate brake light lead, but if your trailer is already wired for 4-wire operation, there are several conversion kits out there on the websites, or someone may chime in here with a suggestion.
If you want to build your own....I have the plans and have shared them with several other trikers.
Old Oct 24, 2010 | 07:19 PM
spider2's Avatar
spider2
I forgot to mention that I want the hitch for a 2011 Ultra Classic. I want the one that 1550vt mentioned. Where the hitch cannot be seen with the draw bar removed. Any suggestions? I no Bushtec makes one and I am sure others also.
Old Oct 24, 2010 | 11:43 PM
Mntsnow's Avatar
Mntsnow
Khromewerks.com makes a hidden receiver model. I have the flhx model and love it.
http://www.khromewerks.com/trailer_hitches.htm about half way down the page
Old Oct 24, 2010 | 11:48 PM
2002flstc's Avatar
2002flstc
Take a look at HitchDoc
E-Rawk924
Aug 7, 2018 05:25 AM
BinIdaho
39
Sep 25, 2011 09:14 PM
gus3836
Aug 6, 2011 08:07 AM
v2plus15
Jul 3, 2009 09:55 PM
Mikeeeeeeeeee
Jun 18, 2006 09:37 AM
