Harley-Davidson Street 500 and 750
Speedometer question
Old May 1, 2017 | 11:01 AM
ktp1598's Avatar
ktp1598
Default Speedometer question
Just bought a 2016 Street 750. Does anybody know if the harness to the speedometer carries the rpm's and gear position information like most all of the other Harley's? I replaced my speedo on my LR-S with one from a Pro-Street Breakout (Has a tach) and everything on it works perfect. Changed one on 2 sportster and they worked too. I just wonder if one from a 2017 Street would be plug and play? Those look the same but have all the info I want, just on the small screen. All I would need to do is wire in a small switch for the toggle. Any ideas? By the way, didn't get a 2017 because I got a new left over '16 for $2400 cheaper!
Old May 1, 2017 | 12:39 PM
nollid51's Avatar
nollid51
I can't say for certain, but I do know that the 17+ have a different wiring harness. It's likely you can't just swap out the speedo to a 2017 unit. The most common option folks use seems to be hooking up an FP3.
Old May 1, 2017 | 01:08 PM
ktp1598's Avatar
ktp1598
Been reading up on the '17s and I don't think they have a digital reading for the tach anyway. I'll come up with something..
Old May 1, 2017 | 03:40 PM
lh4x4's Avatar
lh4x4
The rpm and trip B showed up for the 17's but no gear indicator.
Old May 1, 2017 | 07:13 PM
ktp1598's Avatar
ktp1598
I wonder if that's in the programming or in the cluster. I'd hate to buy a replacement 2017 cluster only to find out it was in the ECM. I'll have to get a part # and price for the '17 cluster and if it's not too bad I may experiment. Thanks lh4x4.
Old May 3, 2017 | 10:13 AM
thndrchiken's Avatar
thndrchiken
My 17 Street 750 has the gear indicator and tach on the same screen as well as the trip b.
Old May 3, 2017 | 11:01 AM
ktp1598's Avatar
ktp1598
I think I'll look into getting a 2017 cluster. Should be able to get one for around $170.
Old May 3, 2017 | 11:03 AM
ktp1598's Avatar
ktp1598
Thndrchiken, does it show a clock as well?
Old May 3, 2017 | 10:09 PM
thndrchiken
Yes it does, in descending order it is:
Odometer, trip a, trip b, clock, gear indicator/engine rpm.
Old May 4, 2017 | 05:01 AM
ktp1598's Avatar
ktp1598
Great. I'll try swapping the cluster in a few days. Gotta find the best place to buy one 1st. Also, I just installed Fuel Motos H4 LED headlight bulb. Really bright! I'll report later on the road pattern.
